Eugen Graf Posted June 14, 2008 Report Posted June 14, 2008 Hello LAVAs! I get following error and don't know how to. Please help! Thank you, Eugen Quote
Francois Normandin Posted June 14, 2008 Report Posted June 14, 2008 You have to Disconnect your Type Def.You must have erased the CTL or moved it somewhere else.EDIT: You also have errors in "Core_Start.vi", but that I'm sure you can fix. Quote
Eugen Graf Posted June 14, 2008 Author Report Posted June 14, 2008 QUOTE (normandinf @ Jun 13 2008, 09:43 PM) You have to Disconnect your Type Def.You must have erased the CTL or moved it somewhere else. Thank you for reply, but I want the Output should automatically update if I update my typedef. QUOTE (normandinf @ Jun 13 2008, 09:43 PM) EDIT: You also have errors in "Core_Start.vi", but that I'm sure you can fix. Of course, I am in programming phase. This VI is not ready to go now. EDIT: Ok, I did it on my way. I redefined my queue to binary string type. Not only due to this problem, much more I want to stay compatible to other programming languages. Quote
Francois Normandin Posted June 15, 2008 Report Posted June 15, 2008 QUOTE (Eugen Graf @ Jun 13 2008, 03:50 PM) Thank you for reply, but I want the Output should automatically update if I update my typedef.Of course, I am in programming phase. This VI is not ready to go now. EDIT: Ok, I did it on my way. I redefined my queue to binary string type. Not only due to this problem, much more I want to stay compatible to other programming languages. Now I understand your question... sorry about my stupid answer! Duh. Quote
