electrika Posted July 10, 2008 Report Posted July 10, 2008 Hello everyone I am an Industrial Engineering major working on a project for summer in a manufacturing systems lab in my university. The system which I am working on uses labview for controlling the motion of a tool along the 3 axes. I am trying to understand the system and later try to see what I can do to improve it. I have not really worked on Labview before so I do need some help...( hope you guys will be here!) My first question is I am trying to write the data generated by labview to an excel file. The thing is that I have two sources of data and I want to write the data from each source to two different columns of the same excel sheet. Since I am not very well versed with labview I am not sure if this is possible. How can i do this? Thanks! Quote
Yair Posted July 10, 2008 Report Posted July 10, 2008 Welcome to LAVA. Here are some tutorials which might help you. As for the Excel issue, you can use the Write to Spreadsheet File VI, which allows you to generate a CSV file, which can be opened by Excel. You can make a 2D array from two 1D arrays by using the Build Array primitive. Quote
Tim_S Posted July 10, 2008 Report Posted July 10, 2008 QUOTE (electrika @ Jul 9 2008, 03:01 PM) I am trying to write the data generated by labview to an excel file. The thing is that I have two sources of data and I want to write the data from each source to two different columns of the same excel sheet. Since I am not very well versed with labview I am not sure if this is possible. How can i do this? Yes, it is possible. However... you may wish to use a CSV file, which is fully compatible with Excel; this would be much easier to implement. This would involve opening a text file and writing out any header, then write out your values. CSV is pretty widely known and documented, so I won't go into that. Tim Quote
electrika Posted July 10, 2008 Author Report Posted July 10, 2008 Hi, Thanks a lot guys! will be back with more questions Quote
