Forcing Relays via rs232
ikos74
Hello everyone,
I’m new to Labview and i would appreciate it if someone could show me how to make, or use an existing Labview VI to operate via RS232 (ASCII or Modbus) an external Power Relay Output (Advantech ADAM 4069), in order to switch on and off a vacuum pump.
The problem is that no Labview VI or driver exists yet from Advantech. However, according to the manual I have to send simple hex command like 0x01 for Set and 0x00 for Reset, through a serial port.
Product Page of Power Relay Output:
http://www.advantech.com/products/8-ch-Pow...d_1-2MLDJ5.aspx
The event which will set or reset the relay is a dc voltage reading acquired by an internal PCI Multifunction Card, for which several VI’s exists.
Thanks in advance for any help!
Regards,
John
QUOTE (ikos74 @ Jul 10 2008, 06:10 PM)
  Quote
Years ago I used the ADAM 4017 (Analog Input) / 4050 (Digital I/O) at the university with LabVIEW 5.1.
Here is the code for the 4050 (If you can't open it, you can open the word doc and reprogramm it...):
It's not the style I programm today, but it worked...
Download File:post-1396-1215756572.zipDownload File:post-1396-1215756587.zipDownload File:post-1396-1215756677.zip
