UDP sender and reciver
HI,
I want to make two programs, first will be sending data from daq (4 channels, 1000 probes) , second will be receiving data from this first program.
I have one problem because this second program receive not the same numbers of data and those charts are diffrent.
First two pictures is sending program , 3,4 picture is receiving program.
Please help me, how to do this second program to read the same number of data which is sending this first program.
QUOTE (Draqo85 @ Jul 18 2008, 03:24 PM)
Use a conditional terminal when you Read UDP data (or monitor error, timeout code = 56). If it's empty, do nothing, else append your data.
I want to send data to more than one computer not always in LAN connection.
There will be one serwer program, and lots of clents programs , which will be reciving probes from serwer.
I thought that for this situation better is UDP.
QUOTE (Draqo85 @ Jul 18 2008, 12:49 PM)
Check out the examples TCP client-server.. there are some examples that do what you need (multiple clients). Also, you can avoid having to deal with communication if you use LabVIEW Shared variables. You can define a buffer for each variable so as to not loose data.
Again, see some examples of communication using shared variables. For simple cases, it will save you a lot of time. For high performance, you might have to use TCP or UDP.
Neville.
QUOTE (normandinf @ Jul 18 2008, 09:46 PM)
I've tried doing this way, but I have still the same problem.
I've check , and always its only 1024 data sent, never more. I think this is because of Windows.
How to sent data in many packages. For example if I want to send more than 2000 probes, what I need to do?
For my programs I'm using Daq simulations, how will this program look like for real Daq measure? Does it will be the same problem with sending data?
I dont have yet NI Daq card, I want do do first program, and then I will be testing it on real NI card.
UDP over LAN restricts you to 8192 bytes per send (1024 x 8 bits). For larger datasets, you'll need to send in many packets and find a way for your receivers to "know" how to concatenate the pieces together. Use some wrapper brackets or tags for sending large datasets.
QUOTE
How will you broadcast if not through a LAN? Do you have an other mean of connecting your clients to the server?
A UDP is nice to avoid management of connections, but you can never be sure that the client received the data, or even how many clients are connected. For diagnostic purposes, I would tend to agree with NevilleD and use TCP.
QUOTE (normandinf @ Jul 19 2008, 02:04 PM)
...unless you impliment your own handling on top of UDP. That said, that's not something you'll want to do unless you have some very specific needs that TCP can't provide.
Thanks, I've tried using TCP connection and it works:)
I thought that TCP will be to slow so I've tried UDP, but now when my programs are working with TCP I see that it is even quite fast (at least for my needs).
Thanks!:)
QUOTE (Draqo85 @ Jul 20 2008, 10:59 AM)
Right - speed is certainly a vaild reason to use UDP, but only if you truly need it. Also, what are often thought of as limitations (no ability to garuntee packet delivery, no packet delivery tracking, multicasting, etc) can be very powerful (but with power comes responsibility :) ) TCP is great if you don't need those things, as it does it all in the background for you.
  • 3 weeks later...
I have one more question.
I'm using TCP connection between "serwer program" and "client program". Serwer program is running all time (send data with TCP), client program is running for a short time (collect data), when I'm starting next time client program (serwer is running all time) I can't collect data, it is working but without connection. Why?
What to do if I want to collect data each time when I will run this client program?
Thanks for help in advance.
