Screenshot utility
QUOTE (Neville D @ Jul 24 2008, 12:28 PM)
I thought John Lokanis had written a utility that did just that.. check out the LAVA CR.
Unfortunately, that one is pretty expensive when you include the ~$2000 for LV8.5. :(
Also, based on the description, his saves the screenshot to an image file - I wanted something that would dump it into a document, saving myself having to switch windows and hit Ctrl-C.
QUOTE (Gary Rubin @ Jul 24 2008, 09:35 AM)
Fair enough.. you could build an exe, you know.. ;)
Neville.
Word has a fairly complete object model and I'm sure it's reasonably easy to add an image into a document. There should be some shipping examples of working with the Word ActiveX interface.
You might run into issues with different versions of Word, accessing an already open document, etc.
QUOTE (Yair @ Jul 24 2008, 01:03 PM)
I seem to have found what I was looking for. Since I'm not looking for a project, $20 (or free for 30 days) is a pretty good deal.
QUOTE (Gary Rubin @ Jul 24 2008, 10:09 AM)
FWIW, you could use the report generation toolkit functions along with the example I created to automatically create a word doc and insert the image into it. You could then build all this into a small app and distrubute it to whomever needed this functionality. All you need is the LV8.5 Full Dev Suite on your machine to do this. Don;t we all have that? ;)
