jgcode Posted August 10, 2008 Report Share Posted August 10, 2008 Hey! Now with virtualisation coming to the forefront of application development evolution - I vote we start a LV + VMWare forum on LAVA! Any takers...might know one :question: ************************************************ Hi My question is whether people have sucessfully run a USB DAQmx device in VMWare Player. I am having issues. I don't install LV on the host as its not a clean unistall and I don't like to run muliple versions of LV. Hence I love VMWare for this reason and having seperate version of LV. But I am using a USB device on a current project and am having issues. VM Server does not seem to pick up any USB device that is why I am using VM Player. Details below: NI Hardware - USB 6009 Software - VM: LV 8.5.1 & DAQmx 8.7.1 Host: LV 8.5.1 Run Time only & DAQmx 8.7.1 CPU - 2.4Ghz Quad Core. RAM - 4GB. OS - Vista Ultimate hosting VM Ware player (latest release) running XP SP2. I am getting a -50150 error on my USB 6009 running in VMWare I wrote a DAQ application and then weird things started to happen [entering the twilight zone] On the first allocation of resources (task, clock etc) everything is fine and I get normal results. At the end of collection I deallocate resources (stop DAQ and remove task vi's). Now on a second or subsequent allocations of resources: one of my channels which is added to the task at the front, comes in on the end of the array!! And it is reading at a weird voltage! I then went into MAX to test panels and when I run the channel I get the -50150 error Then MAX seems to clear it and its all ok as I can run that channel from the test panel. So I made a build so I tested the code on the host (runtime only). I noticed the switch over to the USB device between OS's wasn't that clean. So I shut down the VM. Unplugged the 6009 and plugged it back in. The host picked up the 6009. Then I ran my code and it was fine. Anyone experienced this before with USB DAQmx and a VM? I found this and this in the KB that is kinda related. Cheers JG Quote Link to comment
Justin Goeres Posted August 14, 2008 Report Share Posted August 14, 2008 QUOTE (jgcode @ Aug 8 2008, 04:29 PM) Anyone experienced this before with USB DAQmx and a VM? I've not yet used any USB DAQmx hardware with VMWare on my MacBook Pro. I did try some USB DAQmx stuff about 18 months ago with a beta of Parallels and had lots of weird problems. Basically, the only real solution was to keep the device unplugged until I needed it, plug it in, and then unplug it again and unmap/remap the serial port in Parallels every time I shut down my app. I doubt the situation is still that bad (it was a beta, after all), but that's my only data point. Sorry I can't be of more help. Eventually I will know more about this kind of thing . Quote Link to comment
jgcode Posted August 14, 2008 Author Report Share Posted August 14, 2008 Cheers for the input! QUOTE (Justin Goeres @ Aug 13 2008, 07:45 AM) Eventually I will know more about this kind of thing . Career move? Quote Link to comment
