Project Scanner
post-181-1218497412.png?width=400
Description:
This toolkit will scan the active project for any SCC anomalies in the following categories:
- Files not in SCC
- Files not up to date (a newer version exists in SCC)
- Files not checked in
Additionally it checks if the following two things:
- Files are located under the lvproject folder
- Files that are in the dependency list but not under the LabVIEW executable folder
This toolkit uses the LabVIEW built in SCC VIs.
Instructions:
Unzip to a custom location, or install the OGP using VIPM (www.jkisoft.com/vipm).
To use the toolkit you have to call it from the menu of a LabVIEW window.
Submitter: Ton
File Version: 1.7.3
LabVIEW Version: 8.5.x
License: The BSD License
Admin Note: this LAVAcr submission has been moved from the submission queue to the Code Repository In-Development area due to inactivity timeout.
QUOTE (crelf @ Aug 12 2008, 01:33 AM)
Note from the author:
Thanks for putting this online while I had not the time to put development time in this tool. :thumbup:
I have some issues with my computer at this moment involving LabVIEW and other pieces of software.
This tool will get updates in the (near?) future. Don't hesitate to give feedback here.
Ton
QUOTE (Ton @ Aug 12 2008, 12:27 AM)
No problem - I had the choice of either putting it here or removing it from the queue entirely :D so the choice was obvious...
