Norm Kirchner Posted September 11, 2008 Report Share Posted September 11, 2008 So I'm having some issues w/ trying to build an array of control references if one of the controls is an XControl. Which doesn't make ANY sense to me since the both fall under the 'Control' Class as a common denominator. So in order to prove that to myself, I made a constant of each of these references and started looking at the class membership hierarchy. This is what I got So 2 things. Apparently the XControl class doesn't know which class it belongs to (definitely not TE logging) And it breaks the build array for the references. And even when I straighten out its identity crisis and tell it what it is, it still breaks the build array. WEIRD Quote Link to comment
Aristos Queue Posted September 11, 2008 Report Share Posted September 11, 2008 How far back does this bug exist? (XControls were introduced in 8.0 so you might just test that version directly.) Quote Link to comment
Norm Kirchner Posted September 11, 2008 Author Report Share Posted September 11, 2008 The CAR ID for the broken wire problem is 125719. The problem with both XControls being selected in the class list, NI is already aware of this and should be filing a CAR soon. Workaround for the build array...... put the XControl as the top element inputs to the build array and no broken wires. QUOTE (Aristos Queue @ Sep 10 2008, 03:12 PM) How far back does this bug exist? (XControls were introduced in 8.0 so you might just test that version directly.) Not tested yet. Will give a whirl later tonight. Quote Link to comment
Aitor Solar Posted September 12, 2008 Report Share Posted September 12, 2008 QUOTE (Norm Kirchner @ Sep 10 2008, 11:28 PM) Workaround for the build array...... put the XControl as the top element inputs to the build array and no broken wires. The build array bug is known at least from 8.2. In fact I think we talked about it here, but can't find the topic Saludos, Aitor Quote Link to comment
