maybe Posted September 17, 2008 Report Posted September 17, 2008 I am trying to plot two surfaces on the CWgaph3d. I have two set of data, both set contains 3 points (each points has the x, y and z position) in the 3D space. Please refer to the file I attached. I can plot 1 surface without problem, but I need help on plotting 2 surface on the same control. I have been trying different things and I can not get it, anyone has idea how to approach it? Quote
LAVA 1.0 Content Posted September 17, 2008 Report Posted September 17, 2008 QUOTE (maybe @ Sep 16 2008, 03:23 AM) I am trying to plot two surfaces on the CWgaph3d. I have two set of data, both set contains 3 points (each points has the x, y and z position) in the 3D space. Please refer to the file I attached. I can plot 1 surface without problem, but I need help on plotting 2 surface on the same control. I have been trying different things and I can not get it, anyone has idea how to approach it? Please take a http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=144155#M144155' target="_blank">look at this thread on the NI forum (the Dark Side). It includes example of about 95% of the most commonly used 3d graph functionality including multiple plots of varying styles. Have fun, Ben Quote
