ivan00 Posted October 22, 2008 Report Posted October 22, 2008 Hi ! just discovered the openG site. To opwn/use those vi's one needs the vi-manager. Does the new version of vi-manager work on my 7.1 LabVIEW ? As I'am still looking for a appropiate filter for my 1D array ... Thanks Ivan Quote
Yair Posted October 22, 2008 Report Posted October 22, 2008 VIPM is a separate application, so it will work with any LabVIEW version (at least any version that comes with a VI server connection, which 7.1 does). I think you need to download and install the relevant RTE separately, but I'm sure the JKI site has the exact instructions. As for the OpenG packages, most of them were written using LV 6.1, so they will work with any version newer than that, but some were written in newer versions and you won't be able to use them. VIPM manages that for you as well. Quote
Jim Kring Posted October 22, 2008 Report Posted October 22, 2008 QUOTE (ivan00 @ Oct 21 2008, 11:33 AM) Hi !just discovered the openG site. To opwn/use those vi's one needs the vi-manager. Does the new version of vi-manager work on my 7.1 LabVIEW ? As I'am still looking for a appropiate filter for my 1D array ... Thanks Ivan Hi Ivan, In order to install VIPM 2.0, you will need to download and install the LabVIEW 8.2.1 Run-Time Engine. There are details on installing VIPM and obtaining the OpenG libraries, here. You'll find this video tutorial useful. Also, for filtering the array, you'll want to make sure that you have the oglib_array package installed. Thanks, -Jim Quote
