horatius Posted November 4, 2008 Report Share Posted November 4, 2008 for example png screenshot of the whole block diagramm screen shot shortcut of windows (Alt+Print) is not the appropriate method as it captures only the currently visible part Quote Link to comment
Francois Normandin Posted November 4, 2008 Report Share Posted November 4, 2008 QUOTE (horatius @ Nov 3 2008, 05:25 PM) for example png screenshot of the whole block diagramm There is a Method (Invoke Node) for doing that. Block Diagram>> Get Image Scaled. Then save the image data to PNG. Or you can install the http://forums.lavag.org/Code-Capture-Tool-file121.html' target="_blank">Code Capture Tool from the Code Repository. Quote Link to comment
horatius Posted November 4, 2008 Author Report Share Posted November 4, 2008 QUOTE (normandinf @ Nov 3 2008, 11:29 PM) Block Diagram>> Get Image Scaled. I can't find this procedure. However Code Capture Tool worked excellent. Many thanks. Quote Link to comment
Minh Pham Posted November 4, 2008 Report Share Posted November 4, 2008 QUOTE (horatius @ Nov 4 2008, 10:49 AM) I can't find this procedure. Vi Ref >> Invoke node >> Get Img Scaled As shown: Quote Link to comment
Francois Normandin Posted November 4, 2008 Report Share Posted November 4, 2008 QUOTE (horatius @ Nov 3 2008, 06:49 PM) I can't find this procedure.However Code Capture Tool worked excellent. Many thanks. No prob. And thanks to Minh, you get a screenshot for the same price! BTW, you should create or select an avatar... When you reach the tenth post, it's about time you do. Quote Link to comment
PaulL Posted November 5, 2008 Report Share Posted November 5, 2008 For the record, you can also use the File...Print menu on the VI and print to an html report, which generates .png files. Quote Link to comment
horatius Posted November 6, 2008 Author Report Share Posted November 6, 2008 QUOTE (Paul_at_Lowell @ Nov 4 2008, 05:09 PM) For the record, you can also use the File...Print menu on the VI and print to an html report, which generates .png files. this works very well, I get a PNG file as I want then you don't have to install this Code Capture Tool Quote Link to comment
TobyD Posted November 6, 2008 Report Share Posted November 6, 2008 QUOTE (horatius @ Nov 5 2008, 08:09 AM) this works very well, I get a PNG file as I wantthen you don't have to install this Code Capture Tool True, but the CCT rocks! Why would you not want to install it??? Quote Link to comment
horatius Posted November 6, 2008 Author Report Share Posted November 6, 2008 QUOTE (TobyD @ Nov 5 2008, 08:57 PM) True, but the CCT rocks! Why would you not want to install it??? yes, with CCT not so many mouse clicks Quote Link to comment
