How can I save the whole block diagramm as a picture?
QUOTE (horatius @ Nov 3 2008, 06:49 PM)
I can't find this procedure.
However Code Capture Tool worked excellent.
Many thanks.
No prob. And thanks to Minh, you get a screenshot for the same price!
BTW, you should create or select an avatar... When you reach the tenth post, it's about time you do. ;)
QUOTE (Paul_at_Lowell @ Nov 4 2008, 05:09 PM)
For the record, you can also use the File...Print menu on the VI and print to an html report, which generates .png files.
this works very well, I get a PNG file as I want
then you don't have to install this Code Capture Tool
QUOTE (horatius @ Nov 5 2008, 08:09 AM)
True, but the CCT rocks! Why would you not want to install it???
