Randy Posted November 6, 2008 Report Share Posted November 6, 2008 I'm looking at implementing a system that publishes a vi through the labview web server for remote access/control. I'd like to be able to view this webpage on a PDA/Windows CE device and was wondering if there is a runtime deployment for Windows CE that would allow this kind of remote panel type setup since I've needed to install runtime on PC based machines with a similar setup. I'm operating with LV8.6 on the system acting as a web server. Thanks Link to comment
jgcode Posted November 6, 2008 Report Share Posted November 6, 2008 QUOTE (Randy @ Nov 6 2008, 12:46 AM) I'm looking at implementing a system that publishes a vi through the labview web server for remote access/control. I'd like to be able to view this webpage on a PDA/Windows CE device and was wondering if there is a runtime deployment for Windows CE that would allow this kind of remote panel type setup since I've needed to install runtime on PC based machines with a similar setup. I'm operating with LV8.6 on the system acting as a web server.Thanks About 3-6 months ago I inquired to NI Support about Remote Panels running on a Windows CE Touch Screen (specifically TPC-2012) [LV8.5.1]. The response was that Remote Panel is not supported on that OS - something to do with the browser I think. I will see if I can find the exact response in my work inbox if I still have it. So the last I heard a method like this won't work - we had to implement a custom solution (VI). Link to comment
Randy Posted November 8, 2008 Author Report Share Posted November 8, 2008 Thanks, kind of what I was thinking from the research I've conducted...I think we'll move to a panel PC with a full blown OS instead. Thanks again, Randy QUOTE (jgcode @ Nov 5 2008, 04:23 PM) About 3-6 months ago I inquired to NI Support about Remote Panels running on a Windows CE Touch Screen (specifically TPC-2012) [LV8.5.1].The response was that Remote Panel is not supported on that OS - something to do with the browser I think. I will see if I can find the exact response in my work inbox if I still have it. So the last I heard a method like this won't work - we had to implement a custom solution (VI). Link to comment
Yair Posted November 9, 2008 Report Share Posted November 9, 2008 If you only want to view the remote panel, I believe you should be fine, although I don't remember trying it on WinCE. Controlling won't work because you need the LV RTE, which is not available for CE. Link to comment
Please sign in to comment
Sign In Now
