Randy Posted November 6, 2008 Report Share Posted November 6, 2008 I'm looking at implementing a system that publishes a vi through the labview web server for remote access/control. I'd like to be able to view this webpage on a PDA/Windows CE device and was wondering if there is a runtime deployment for Windows CE that would allow this kind of remote panel type setup since I've needed to install runtime on PC based machines with a similar setup. I'm operating with LV8.6 on the system acting as a web server. Thanks Quote Link to comment
jgcode Posted November 6, 2008 Report Share Posted November 6, 2008 QUOTE (Randy @ Nov 6 2008, 12:46 AM) I'm looking at implementing a system that publishes a vi through the labview web server for remote access/control. I'd like to be able to view this webpage on a PDA/Windows CE device and was wondering if there is a runtime deployment for Windows CE that would allow this kind of remote panel type setup since I've needed to install runtime on PC based machines with a similar setup. I'm operating with LV8.6 on the system acting as a web server.Thanks About 3-6 months ago I inquired to NI Support about Remote Panels running on a Windows CE Touch Screen (specifically TPC-2012) [LV8.5.1]. The response was that Remote Panel is not supported on that OS - something to do with the browser I think. I will see if I can find the exact response in my work inbox if I still have it. So the last I heard a method like this won't work - we had to implement a custom solution (VI). Quote Link to comment
Randy Posted November 8, 2008 Author Report Share Posted November 8, 2008 Thanks, kind of what I was thinking from the research I've conducted...I think we'll move to a panel PC with a full blown OS instead. Thanks again, Randy QUOTE (jgcode @ Nov 5 2008, 04:23 PM) About 3-6 months ago I inquired to NI Support about Remote Panels running on a Windows CE Touch Screen (specifically TPC-2012) [LV8.5.1].The response was that Remote Panel is not supported on that OS - something to do with the browser I think. I will see if I can find the exact response in my work inbox if I still have it. So the last I heard a method like this won't work - we had to implement a custom solution (VI). Quote Link to comment
Yair Posted November 9, 2008 Report Share Posted November 9, 2008 If you only want to view the remote panel, I believe you should be fine, although I don't remember trying it on WinCE. Controlling won't work because you need the LV RTE, which is not available for CE. Quote Link to comment
