Where is the Error Codes Ring constant?
Donald
QUOTE (Ton @ Nov 21 2008, 01:07 PM)
I use this constant since LabVIEW 3 if I remember well. There are many usefull generic errors e.g. Argument Error as you know. This constant is used by a lot of VI.lib VIs, I had no idea it has been depreciated.
What should be used instead of this constant?
When I try to select it from the LV7.x palette (within LV 8.5) nothing happens... with Quick Drop I can still select it but quick drop takes a while to launch on older PCs... Makes no sense :wacko:
Thanks for reminding me it is also on the OpenG palette which I always install.
