Full screen front panel in Linux
I am porting a LabVIEW application from Windows to Linux (ubuntu).
I haven't found any functional problems, but I can't get the front panel on the user-interface to go full screen.
In Windows, when you set the front panel property "Window Bounds" to 1024x768, the front panel goes
full screen, and comes in front of the windows taskbar.
When I run the same VI in Linux, the taskbar (with the main menu) is still visible.
Is there a way to run a VI really full screen in Linux?
Thanks in advance,
Thomas.
I suggest you check the settings of your Linux taskbar - on Windows I have the taskbar property "Keep the taskbar on top of other windows" set, so your trick of expanding the window bounds wouldn't put the front panel in front of the taskbar on my machine.
