Kurt Meklenburg Posted December 17, 2008 Author Report Share Posted December 17, 2008 The driver for the Agilent E1472A RF 1x4, 6 Bank Mux Card does not work HPE1472A.LLB Quote Link to comment
Kurt Meklenburg Posted December 17, 2008 Report Share Posted December 17, 2008 The driver for the Agilent E1472A RF 1x4, 6 Bank Mux Card does not work HPE1472A.LLB Quote Link to comment
Neville D Posted December 17, 2008 Report Share Posted December 17, 2008 I've used this module before in the distant past. What Slot0 controller do you have in your chassis? The driver from NI assumed an NI controller if I remember right. Just read up the module info and try to send it simple SCPI command strings first before you try anything more complicated. You should be able to hear a small click as the reed relays inside click on or off. I used an HP GPIB controller, and after some fiddling around was able to make it all work. I had to program the individual registers to get the open/close combinations I needed; can't remember if I used the NI drivers. Neville. Quote Link to comment
