False linking of VI(s) to .svn folder
QUOTE (Jim Kring @ Jan 3 2009, 02:19 PM)
> suddenly it doesn't work the same at all because a bunch of VIs over in a ".svn" directory are being picked up by wildcards
Only if one used improper settings that allowed the .svn folder contents to be included -- the .svn folder contents should be exclude-able in the build spec scheme.
The general pain that I'm describing is caused by the fact that you can only "build" things (exe, zip, installer) from sources that exist in your project. Building a software product typically involves several cascaded build steps (in most situations this is an EXE, followed by an Installer, followed by a ZIP file). The project environment bonks when it can't find project items. And inputs to a build step generally don't exist until a prior build step completes -- this is why, IMO, it doesn't make much sense to require that items exist in the project in order to build them (since the auto-populating folder scheme is so "dumb" in how it auto-populates). Plus, projects (and auto-updating folders) don't update/refresh between build steps. Maybe you could use multiple projects, but this is also a bit of a kludge and means that you can't build in a single step -- it also means that you can't open a downstream project until an upstream project is built. Bottom line: using the project environment to build any non-trivial software product is a painful endeavor -- you should http://thinkinging.com/2008/05/27/a-dogfooding-challenge-to-ni-use-your-application-builder/' rel='nofollow' target="_blank">try it sometime ;)
Ah -- chained building is an entirely different beast. Chained building is a feature I'd support. But the base source files for any link in the chain should all be in the project or another project pointed at by this one. That way every link in the chain is managed by a project file that is very explicit about which source files should be pulled into the build.
