EasyDAQ Posted January 6, 2009 Report Posted January 6, 2009 EasyDAQ are pleased to announce the launch today of a new, low cost, general purpose, 8 channel wireless (XBee/RF) relay card and USB connected transceiver pair. (From $200/€147/£140). This product offers the following: · XBee transceivers provide a 'transparent' RF connection with a secure and rugged transmission protocol · Range of greater than 100 meters (*line of sight). Works through typical internal walls and ceilings etc. · USB connected/powered XBee transceiver module is a ruggedized design & housed in a small, fully potted, plastic case · Works exactly as if connected by a USB cabled connection · Opto-isolated relays & PCB tracking designed to switch 120/240VAC @ 10 amps · Relay contacts are uncommitted & taken to 2 part (male/female) screw terminal connectors allowing rapid connect/disconnect of the card · Relay card is available with a Perspex cover and DIN rail mount option · Code compatible with our existing range of 4, 8, 24 ad 96 channel USB relay cards, this product uses the same simple ASCII/Hex text commands to initialise and control them · Windows/Mac OSX & Linux compatibility. · If you have previously used our serial/USB relay cards, your code can easily be ported to this product · LabVIEW, Visual C, Visual Basic, Delphi or Agilent VEE example programs · Ideal for Engineers, Scientists, Academics, engaged in the design and development of Test, Automation/Control and Instrumentation/Data Logging and Home Automation applications · As with all of our current range USB relay cards, this product is shipped, Worldwide, free of charge Tell me more: & XBee8PRMx relay card.htm Regards, Chris Harden Product Design & Tech Support. We design & supply low cost USB & Serial Port Relay Cards, Automation & Control, Data Acquisition & NIDAQ compatible hardware products. www.easydaq.biz technical@easydaq.biz We have many connections. Connect with us in 2009..... Quote
