What is simple VI and general VI
GSR
I see an MCQ, there are two VIs
one is add 2 number together
one is DAQ vi inside a while loop
which one is simple VI
both of them are simple and general<-- that is what I think
QUOTE (zmarcoz @ Jan 13 2009, 05:33 AM)
This is terminology on design patterns from NI:
Simple VI - block diagram is usually a component/function - typically a subVI
General VI - block diagram contains parts e.g. initialise routine >> main (loop) >> shutdown routine.
Therefore use the above terminology IMHO:
"add 2 numbers" = simple VI
"DAQ vi inside a while loop" = general VI
QUOTE (zmarcoz @ Jan 12 2009, 03:33 PM)
What is "nested formula node" structure mean?
I see this in the CLAD sample exam, which ask formula node accept which of the following operation
Nested structures refers to placing a NI structure inside a NI structure. An example would be placing a case structure inside a case structure or loop inside a loop. You can not place a formula node inside a formula node, so if the question was which one of the below is not valid "nested formula nodes" would be the answer.
