exponential function
I'm a beginner and only started using LabView a few days back.
I would like to learn the basic functions, however i do not have a guide.
As a start, can I know what diagrams I need to input to create an exponential function, and reflect the waveforms?
QUOTE (gareth123 @ Jan 18 2009, 01:37 AM)
this is something which i had tried, however i don't see any output waveforms.
did i miss out on something?
  • You didn't wire anything into the graph
  • Your formula only makes one data point; I think you need a chart instead
  • Your formula calculates to a constant
Try this one
QUOTE (jcarmody @ Jan 18 2009, 01:12 PM)
Try this one
Thanks a lot. It sure helps. i tried to wire the exponential function into the graph but it seems it become loose ends.
To use a formula, can I say that I had to specify an input into the formula, and let the formula operate from there?
Another thing which I'm pretty curious about. At first, my formula was sin(2*pi) and why did you change it to sin(2*pi*mod(i,pi)) instead? what does the "mod(i,pi)" do?
ok. this is something which i had tried earlier. I'm supposed to do a fourier transform of this signal.... exp(-alpha*t) where alpha is greater or less than 0.. the upper limit is inf and lower limit is 0. the waveform i got is a straight line, and there's this error -20003 i.e number of samples > 0.
I thought I had already defined the number of samples? Is that anything which I had missed out? Please see attached.
QUOTE (gareth123 @ Jan 23 2009, 08:12 AM)
updated .vi file. I had changed the -inf icon to a numeric constant and it works. Now I would like to display the waveform in real time domain exponential signal, magnitude spectrum and phase spectrum.
