professor_rumsdiegeige Posted January 24, 2009 Report Posted January 24, 2009 Hello! I read measurement values out of a file. This takes about a minute. After that, I want the user to be able to change the value of a slider, and then display the value of measurement number "value of slider". So I used a flat sequence, and in the last block of this sequence I added an event structure. But obviously this event structure gets active long before: when I start the program with this last block, I can't do anything anymore, and as soon as I remove it, the program works again. So isn't it possible to have an event structure that is only active within a certain block of a sequence? Thanks a lot! Sabine Lorentz Quote
LAVA 1.0 Content Posted January 24, 2009 Report Posted January 24, 2009 Hi Sabine, there are several options (hard to easy): Use dynamic event registration Set the event not to loc the FP (in the options of the event case Ton Quote
professor_rumsdiegeige Posted January 24, 2009 Author Report Posted January 24, 2009 QUOTE (Ton @ Jan 23 2009, 08:29 AM) Quote Hi Sabine,there are several options (hard to easy): Use http://forums.ni.com/ni/board/message?board.id=170&message.id=242266&jump=true' target="_blank">dynamic event registration Set the event not to loc the FP (in the options of the event case Ton Thanks, the second option solved my problem! Quote
