Resetting Vi ,screen message..
Sakis
i am developing an application with several screens .but when the executable runs and change vi's,the screen is flickering a bit and a annoying message appears for milliseconds .
Can you give me any advise ??
I think the annoying message is "resetting VIs" (that little dialog that show up in the upper left corner of the screen).
I have seen this happen, but mostly when closing an application and most of the time it was on Linux. I rarely see this on windows.
PJM
I have attached two projects.
The Untitled_resseting_vi projects appears the message RESETING VI and also there is a white space screen when a screen is closed and the next screen is opened.
In the second project Untitled_screan_flickering.vi we solved the RESETING VI message problem handling the conditional terminal of the while loops. But the white screen between the screens exists.
Can you help me to make the screens open smoothly without the annoying white space between them?
