QUOTE (harika @ Jan 30 2009, 12:43 PM)
hi,
how can we convert an vi to exe file.please help me out.
Thanking you,
Harika.
I assume - from seeing your profile settings - that you have LabVIEW 8.6.
First, to be able to build exe you need to have the FDS (Full Development System) or PDS (Professional Development System) version of LabVIEW, the base LabVIEW can't build exes.
Then if you have FDS or PDS, you must create a LabVIEW project and put your VIs in it to be able to build an exe (that was one of the big changes from LabVIEW 7 to LabVIEW 8).
In the project windows, right clic on "Build Specifications" and select "New.. > Application (EXE)"
Hope this helps
