Ben Zimmer Posted February 20, 2009 Report Posted February 20, 2009 Hey everyone, It has apparently become quite difficult to fit multiple PCI DAQ cards in one modern PC. I need a solution capable of fitting 4 PCI cards. A hardened IPC is not necessary, but if needed, I will go there. Suggestions? Thanks, Ben Quote
gleichman Posted February 20, 2009 Report Posted February 20, 2009 Are you using existing DAQ boards or are you purchasing new? Some DAQ boards are available as PCIe if you are purchasing new. I build my own industrial PCs with motherboards like this one. Intel DG43NB Motherboard (3) PCI (2) PCIe x1 (1) PCIe x16 (video) If you are using GPIB there is a PCIe version. QUOTE (Ben Zimmer @ Feb 18 2009, 09:04 PM) Hey everyone,It has apparently become quite difficult to fit multiple PCI DAQ cards in one modern PC. I need a solution capable of fitting 4 PCI cards. A hardened IPC is not necessary, but if needed, I will go there. Suggestions? Thanks, Ben Quote
jzoller Posted February 20, 2009 Report Posted February 20, 2009 QUOTE (Ben Zimmer @ Feb 18 2009, 07:04 PM) Hey everyone,It has apparently become quite difficult to fit multiple PCI DAQ cards in one modern PC. I need a solution capable of fitting 4 PCI cards. A hardened IPC is not necessary, but if needed, I will go there. Suggestions? Thanks, Ben I've built many of my own computers through Newegg before. http://www.newegg.com/Product/ProductList.aspx?Submit=Property&Subcategory=280&Description=&Type=&N=2000200280&srchInDesc=&MinPrice=&MaxPrice=&PropertyCodeValue=735%3A7582&PropertyCodeValue=735%3A7583' rel='nofollow' target="_blank">4 & 5 slot motherboards It does look like the days of the retail, many-PCI-slot motherboard are coming to a close. Joe Z. Quote
Maca Posted February 20, 2009 Report Posted February 20, 2009 ICP sell a lot of main boards that will do what you want (they still even sell ones with ISA buses on them). http://www.icp-australia.com.au/ They are marketed as industrial main boards but are generally nothing more than cheap consumer grade gear with a CF card slot on the board. But they are relativity cheap as well They also sell other "weird" form factors as well I.e. Passive backplane and ETX. Have fun Note: I have no affiliation with ICP at all Quote
AnalogKid2DigitalMan Posted February 20, 2009 Report Posted February 20, 2009 Advantech sells mobo's and complete IPC's. I think some of their boards/systems support up to 7-10 slots. I think they also have mobos with ISA/PCI You could also go with the Single Board Computer on a passive backplane route. http://www.advantech.com/eplatform/ More IPC's at ICI: http://www.eindustrialcomputers.com/Produc...sp?idCategory=2 -AK2DM Quote
