Producing a graph
star
The reason why I want to make a graph is because I am reading some values for a text file and then place the values on the graph. The x-axis is the number of items in the file and y-axis are the values. I made a code that reads from a text file and I have attached it below.
QUOTE (star @ Feb 27 2009, 04:32 AM)
We don't know what your output string looks like, but essentially you need to convert your data to an array of numbers and pass that into your graph. Because your x-axis is just a count of data points you'll be better off using a waveform graph instead of an XY Graph. Look at the help for graphs for more info.
QUOTE (TobyD @ Feb 27 2009, 03:13 PM)
Now you can see what my output string looks like and i look at some waveform graph instead of an XY Graph and i still couldn't do it.
Thanks for your reply
