BobbyCee Posted February 27, 2009 Report Posted February 27, 2009 I am trying to programmatically scroll the entire Front Panel vertically, after programmatically resizing a window. Any suggestions on how to access the vertical scroll position would be great! Quote
hooovahh Posted February 27, 2009 Report Posted February 27, 2009 Use the Position Property Node for that Scrollbar. Right click the Vertical Scrollbar, select Create, Property Node, Position, All. Then change that Property Node to a write, and wiring in the X and Y coordinates. Quote
