jcarmody Posted March 1, 2009 Report Posted March 1, 2009 I'm developing an ATE that needs to communicate with a UUT that contains a microprocessor with a HOLD line. I can manipulate the UUT as long as I keep that pin high; the microprocessor takes over as soon as I drop it. These UUTs haven't had their programs loaded by this time (that's part of my ATE's job) so a watchdog takes over and the UUT isn't addressable until I cycle its power. (There are a few other lines/states that I need to maintain in order to conduct my tests.) The problem I have is that I have to do a bunch tests and I use a few different FPGA programs to do them. I believe that the digital outputs are dropping when I push a new program to the target and I loose the control lines that allow me to work. I can regain control by resetting the outputs and cycling power every time I change FPGA programs, but I'd rather not (it just doesn't seem right.) My current solution is to take all of the individual programs and unpack them into one Uber-FPGA program (I'm compiling that now) but the block diagram is large and it hurts me when it doesn't fit on one screen. Is there a way to keep the digital output lines from dropping when I change programs? Thanks, Jim Quote
LAVA 1.0 Content Posted March 1, 2009 Report Posted March 1, 2009 QUOTE (jcarmody @ Feb 28 2009, 08:53 AM) Is there a way to keep the digital output lines from dropping when I change programs? Jim, I'll check on this Monday when I get back to the office. Can you let me know which HW and what LV version you are using? Quote
jcarmody Posted March 3, 2009 Author Report Posted March 3, 2009 QUOTE (LV_FPGA_SE @ Feb 28 2009, 03:30 PM) Can you let me know which HW and what LV version you are using? I've got a PXI-7813R connected to a cRIO-9151 expansion chassis containing two NI-9403 DIO modules, and LabVIEW 8.6. Quote
