rpscott02 Posted March 3, 2009 Report Share Posted March 3, 2009 I wanted to know if it were possible to store a property node in a sub Vi to have it activate an indicator in a main VI. For example, I want to have an indicator blink when a TCP connection is found. Can I store a blinking property node in a sub-VI and have the indicator in the main VI (that is connected to the sub-VI output) then blink? I've attached the VI below. Thanks Quote Link to comment
jdunham Posted March 3, 2009 Report Share Posted March 3, 2009 QUOTE (rpscott02 @ Mar 2 2009, 01:44 PM) I wanted to know if it were possible to store a property node in a sub Vi to have it activate an indicator in a main VI. For example, I want to have an indicator blink when a TCP connection is found. Can I store a blinking property node in a sub-VI and have the indicator in the main VI (that is connected to the sub-VI output) then blink? I've attached the VI below. Thanks 1. Right-click on the property node and choose "disconnect from control". 2. Right-click on your control and choose Create -> Reference. This reference can be wired into the disconnected property node. 3. Select the property node (but not the reference) and choose [menu] -> Edit -> Create SubVI... 4. Use the SubVI as needed. Quote Link to comment
jgcode Posted March 3, 2009 Report Share Posted March 3, 2009 QUOTE (rpscott02 @ Mar 3 2009, 06:44 AM) I wanted to know if it were possible to store a property node in a sub Vi to have it activate an indicator in a main VI. For example, I want to have an indicator blink when a TCP connection is found. Can I store a blinking property node in a sub-VI and have the indicator in the main VI (that is connected to the sub-VI output) then blink? I've attached the VI below. Thanks Hi Rpscott02 I am guessing you are able to create an implicitly linked property node by right-clicking a control and selecting create>>property node? You can use property nodes in subVIs by using explicitly linked property nodes. To create an explicitly linked property node you need to create a control reference (by right-clicking a control and selecting create>>control reference) for the control object and wire it to the generic property node (found on the Functions>>Application Control sub-palette). Depending on the version of LabVIEW you have, an easier way is to place a marquee around some implicitly linked property nodes (i.e. to select them with the mouse) then go to edit>>create subvi and LabVIEW will do the above for you. Don't forget to close your references! This tut should be good information for you. Quote Link to comment
rpscott02 Posted March 4, 2009 Author Report Share Posted March 4, 2009 QUOTE (jgcode @ Mar 2 2009, 05:26 PM) Hi Rpscott02I am guessing you are able to create an implicitly linked property node by right-clicking a control and selecting create>>property node? You can use property nodes in subVIs by using explicitly linked property nodes. To create an explicitly linked property node you need to create a control reference (by right-clicking a control and selecting create>>control reference) for the control object and wire it to the generic property node (found on the Functions>>Application Control sub-palette). Depending on the version of LabVIEW you have, an easier way is to place a marquee around some implicitly linked property nodes (i.e. to select them with the mouse) then go to edit>>create subvi and LabVIEW will do the above for you. Don't forget to close your references! This tut should be good information for you. Thanks jdunham and jgcode! Both your suggestions worked and are greatly appreciated Quote Link to comment
rpscott02 Posted March 6, 2009 Author Report Share Posted March 6, 2009 One more issue - i'm having trouble making the blinking property node activate on after an even happens (namely, a 'no error' signal from another subVI). For some reason, it blinks as soon as I begin running the program. I've tried event and case structures and neither worked. I thought simply putting the property node in the error flow would cause things to happen sequentially but no luck there either. Any suggestions? Quote Link to comment
jgcode Posted March 6, 2009 Report Share Posted March 6, 2009 QUOTE (rpscott02 @ Mar 5 2009, 10:31 PM) One more issue - i'm having trouble making the blinking property node activate on after an even happens (namely, a 'no error' signal from another subVI). For some reason, it blinks as soon as I begin running the program. I've tried event and case structures and neither worked. I thought simply putting the property node in the error flow would cause things to happen sequentially but no luck there either. Any suggestions? I will take a stab in the dark here without seeing your code... if you are wiring an error to a property node and the wire contains an error then the property node will not run. Quote Link to comment
rpscott02 Posted March 6, 2009 Author Report Share Posted March 6, 2009 QUOTE (jgcode @ Mar 5 2009, 08:59 AM) I will take a stab in the dark here without seeing your code... if you are wiring an error to a property node and the wire contains an error then the property node will not run. Ok, my excellent typing skills may have made thing a bit unclear. I meant that the blinking node is working, just that it starts as soon as the program is run and not when I want it to. I want it to activate at a certain point in the program. I have currently a case structure that checks if there is an error in the program and if NOT then the blinking property node should begin blinking. For some reason, this is not working. Hope that clears things up Quote Link to comment
george seifert Posted March 6, 2009 Report Share Posted March 6, 2009 QUOTE (rpscott02 @ Mar 5 2009, 09:25 AM) Ok, my excellent typing skills may have made thing a bit unclear. I meant that the blinking node is working, just that it starts as soon as the program is run and not when I want it to. I want it to activate at a certain point in the program. I have currently a case structure that checks if there is an error in the program and if NOT then the blinking property node should begin blinking. For some reason, this is not working. Hope that clears things up The blinking state probably got set before the program ended. When it starts up again it'll resume at that state. Set the state at the beginning of your program to make sure it's in a known state. George Quote Link to comment
