BenD Posted March 7, 2009 Report Posted March 7, 2009 Where did my post go? I posted on Feb 27 about doing a functional global that is a timer with pause, it appears to be gone now although the VI I uploaded is showing up in My Controls. What gives? Quote
Antoine Chalons Posted March 7, 2009 Report Posted March 7, 2009 QUOTE (BenD @ Mar 6 2009, 03:49 PM) Where did my post go? I posted on Feb 27 about doing a functional global that is a timer with pause, it appears to be gone now although the VI I uploaded is showing up in My Controls. What gives? Hi, http://forums.lavag.org/Timer-with-Pause-via-Functional-Global-t13420.html' target="_blank">Here is your post. Maybe the moderation team move it from a section to another if they though it was necessary. When a post is moved from a section to another, the link to the post doesn't change though. More generaly, to find posts from a user (the user can be yourself) you can click on the user to see his profile them select "find user's post" from the "option" drop-down menu. Or even directly from the drop down menu on the user name, "find member's posts". Hope this helps Quote
BenD Posted March 7, 2009 Author Report Posted March 7, 2009 QUOTE (Antoine Châlons @ Mar 6 2009, 10:08 AM) Hi,http://forums.lavag.org/Timer-with-Pause-via-Functional-Global-t13420.html' target="_blank">Here is your post. Maybe the moderation team move it from a section to another if they though it was necessary. When a post is moved from a section to another, the link to the post doesn't change though. More generaly, to find posts from a user (the user can be yourself) you can click on the user to see his profile them select "find user's post" from the "option" drop-down menu. Or even directly from the drop down menu on the user name, "find member's posts". Hope this helps Thanks for the tip - I lost track of the forum I'd posted it in. I was sure I'd put it in the Applications discussion! What was bugging me is that there seems to be no way to track your posts from within My Controls. I'd think that somewhere in there should be a listing of your posts. Although your method works just fine, you'd think you'd be able to access it from there and I don't see it. On a side note, if I click on my profile and select the "Posts" tab, it claims that I have no posts! The drop-down menu works just fine though. Quote
Antoine Chalons Posted March 7, 2009 Report Posted March 7, 2009 QUOTE (BenD @ Mar 6 2009, 05:15 PM) Thanks for the tip - I lost track of the forum I'd posted it in. I was sure I'd put it in the Applications discussion! What was bugging me is that there seems to be no way to track your posts from within My Controls. I'd think that somewhere in there should be a listing of your posts. Although your method works just fine, you'd think you'd be able to access it from there and I don't see it. On a side note, if I click on my profile and select the "Posts" tab, it claims that I have no posts! The drop-down menu works just fine though. hmmm.. I think the "Posts" tab in your controls just shows the posts from the last month or week, or maybe the current month. Something alike anyway, so if you haven't post recently it will be empty. to be honest, I also didn't find myself the trick to get the list of all my post. http://forums.lavag.org/user-s-post-list-t12035.html' target="_blank">Yair told me the trick Quote
