Is library part of another library
I'm trying to find out if a given library is part of another libary. I don't get anything sane to work.
For a VI there is a 'Library' property that returns the owning library reference. For a library such feature does not exist.
Even stranger is that the 'Localized Name' or 'Display Name' only contain the bare name of the library.
I currently have one workaround:
post-2399-1237497387.png?width=400
And this solution needs any VI to be inside the lvlib root-folder.
Ton
PS this code needs to be done in 8.2 so any ideas?
Edit:
Darren Twittered
QUOTE
@tonplomp If you have the library's ProjectItem, you can get Parent in a loop until you hit a target or a library.
So I builded the following project setup:
post-2399-1237499305.png?width=400
The 'Untitled 4.vi' has the following contents:
post-2399-1237499402.png?width=400
Note that the Parent's ref of the folder is not valid! Somehow the folder inside the top-level library has no valid parent :(
Ton
