RAJKU Posted March 23, 2009 Report Posted March 23, 2009 Can anyone explain we what is the relation between VI sever and Instance. If I open a VI in project instance and I use a property node to get the VI server port configured it shows me zero and when I do the same in Main Instance I get the port number what is configured. Can anyone explain me how are they related and why are they related. Thanks Quote
Val Brown Posted March 23, 2009 Report Posted March 23, 2009 QUOTE (RAJKU @ Mar 22 2009, 10:37 AM) Quote Can anyone explain we what is the relation between VI sever and Instance. If I open a VI in project instance and I use a property node to get the VI server port configured it shows me zero and when I do the same in Main Instance I get the port number what is configured. Can anyone explain me how are they related and why are they related. Thanks Can you post code or at least a screen capture of code? Quote
RAJKU Posted March 23, 2009 Author Report Posted March 23, 2009 QUOTE (Val Brown @ Mar 22 2009, 06:49 PM) Quote Can you post code or at least a screen capture of code? Here is the screenshot.......Trying to get an insight of what is happening inside QUOTE (RAJKU @ Mar 22 2009, 07:29 PM) Here is the screenshot.......Trying to get an insight of what is happening inside Here the service name is same for both the instance. Dont get confused the I forcefully changed it to main application instance. But it is actually MY computer/VI Server was the service name. Quote
Mark Yedinak Posted March 25, 2009 Report Posted March 25, 2009 I haven't played extensively with the VI Server but are you running one of these in a project and one outside a project? If so, you would need to configure the VI Server for the project. I haven't experimented with this but I suspect you might be able to run multiple VI Server's on a single machine provided you managed your ports properly. Quote
RAJKU Posted March 26, 2009 Author Report Posted March 26, 2009 QUOTE (Antoine Châlons @ Mar 24 2009, 06:07 PM) Quote hope http://wiki.lavag.org/Application_instance' rel='nofollow' target="_blank">this wiki page helps. Thanks for the Link it gave me a good idea and made some study about it Quote
