koisiatin Posted March 24, 2009 Report Posted March 24, 2009 I have some question! Please tell me are exist some function what compare difference of 2 graph's? On the pic you may see the example of graph and in the archiv the example of LV code! the method I use in example not very good! Please help me!!! The example on LV 8.6 Quote
MikaelH Posted March 25, 2009 Report Posted March 25, 2009 Hi The content of the Data (dat) file is not correct, the While loop never terminates. What result are you after? Do you what to see if there is a exact match, or just get a value indicating how good the match is? One solution could be to find the peaks in the different waveforms and compare the locations of these peaks. You could add a LowPass-Filter and then compare the waveform as you did in your code. Cheers, Mikael Quote
koisiatin Posted March 25, 2009 Author Report Posted March 25, 2009 Thanks!But may You tell more detailed about it??? Quote
MikaelH Posted March 25, 2009 Report Posted March 25, 2009 Could you first answer these questions: What result are you after? Do you what to see if there is a exact match, or just get a value indicating how good the match is? And also could you give me some real data to play with. E.g. save the 2 waveforms as "Make Current Values Default". Cheers, Mikael Quote
