XML, XPath and namespaces
NeilA
I have gotten used to the awkwardness of XML in LabVIEW but have just come up against a massive problem of using XPath and trying to parse namespaced xml. Basically where XPath used to do the trick it now doesnt because parts of my xml are in a different namespaces. I cant figure out how to get acces to the namespace manager or anything (which is what you need to do according to google). I need to talk to my colleague who has just added the namespaces and made my day very hard, but, I may just remove them for my simple implementation if there is no way round it in LabVIEW.
I have attached an example XML where I used to be able to loadXML String and then SelectSingleNode with an XPath of /soap:Envelope/soap:Header/UUID/UUID to get the guid.
Any ideas on what to use? I have had a look round in the constructors but cant work out how to do this, is it me or does this just seem like even more hard work, blooming XML :headbang:
Many Thanks in advance..
<?xml version="1.0" encoding="utf-8"?>
<soap:Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/">
<soap:Header>
<UUID xmlns="http://RMS/">
<UUID>guid</UUID>
</UUID>
</soap:Header>
<soap:Body>
<ControlResume xmlns="http://RMS/">
<ParameterList>
<Parameter>
<Type>string</Type>
<Name>string</Name>
<Value>
<string>string</string>
</Value>
<Units>string</Units>
</Parameter>
<Parameter>
<Type>string</Type>
<Name>string</Name>
<Value>
</Value>
</Parameter>
</ParameterList>
</ControlResume>
</soap:Body>
</soap:Envelope>
QUOTE (MJE @ Apr 6 2009, 07:24 PM)
Sorry to be an idiot but could you please explain further? I have tried using different namespaces and xpath combinations but cant get any further, are you suggesting that I still use SelectSingleNode method of the xpath class but with a different xpath!?!
Thanks
QUOTE (Matthew Zaleski @ Apr 6 2009, 09:23 PM)
Welcome to the world of XML. :(
Yeah Thanks,
I have been happily using XPath without any issues but the addition of namespaces has seemed to just add headaches. I dont have control of the namespaces this XML is the soap message sent to me from another system.
I have been playing around with the LabVIEW XML parser property and invoke nodes as they contain a function to ignore the namespaces but the LabVIEW implementation is based around DOM and I find it really cumbersome after XPath plus I dont really want to re-write everything.
Is there any way I can access the namespaces myself (ie namespace manager/nametable (bear in mind I got this info from the net I have only just heard about them and I dont know if I am asking the correct thing lol!))to recover the XPath solutions I have already implemented.
Thanks for the help so far.
Neil.
Sorry, Not to worry chatted to my colleague doing my other system. I am pretty certain that I will always be using the RMS namespace etc. So to make it easier I have the incoming message pass through a vi that removes all the namespace stuff and makes it work again in XPath.
Thanks for all your help though.
