scls19fr Posted April 8, 2009 Report Posted April 8, 2009 Hello, I'm measuring temperature using LabVIEW. I see how temperature is changing versus time in a "rolling plot" (sorry it's probably not the good word for this... but I haven't any idea about its translation) I'd like to print this plot. I'd like to get a very clean printing. (I don't want for example getting just a screen capture) I would like to be able to define scale because some hand writting need to be done on the sheet of paper. What should I do to achieve this ? Is NI DIAdem the solution for my problem ? (I never used it before because I never had to make a report) What should I read first to understand how it works ? Is there a way to do it with DIAdem ? (I'd prefer not using DIAdem) Kind regards Quote
Neville D Posted April 8, 2009 Report Posted April 8, 2009 You can add a print button to your main VI that pops open a separate VI containing the data formatted for printing. It can be white so the print doesn't look grey (or disable greyscale printing in your print options of LV), and have whatever you need. Then print that VI. N. Quote
LAVA 1.0 Content Posted April 10, 2009 Report Posted April 10, 2009 Another trick might be, to get the image of the control with a bit depth of 1 resulting in a black/white image. Ton Quote
scls19fr Posted April 10, 2009 Author Report Posted April 10, 2009 Thanks for this solutions. Maybe you have a minimal example to post here ? Kind regards PS: sorry for being so long to reply but I didn't receive notification Quote
