paramesium Posted April 9, 2009 Report Posted April 9, 2009 Hello , I am doing a project and i need to generate the data into a table as shown as below I have signal from 3 different channels and i have enabled the include time data... but once i did that ..it shows 3 time data for the 3 different signals that i gained... is there anyway to make it only one time data instead of 3 time data? Quote
LAVA 1.0 Content Posted April 9, 2009 Report Posted April 9, 2009 Few pointers before getting to the point: Host you image at LAVA, this way the Portal won't be screwed up by your image size. Use the Code Capture Tool to create High-quality code images Now on topic, have a look at the Array palette and try to delete column number 1 and 2. Ton Quote
paramesium Posted April 10, 2009 Author Report Posted April 10, 2009 QUOTE (Ton @ Apr 8 2009, 09:51 PM) Quote Few pointers before getting to the point: Host you image at LAVA, this way the Portal won't be screwed up by your image size. Use the http://forums.lavag.org/Code-Capture-Tool-file121.html' target="_blank">Code Capture Tool to create High-quality code images Now on topic, have a look at the Array palette and try to delete column number 1 and 2. Ton ok.... thanks for the advise I will try to use "delete from array " option thanks a lot Quote
