Retrieve web-based data using RT Target
Hello all,
Specifically, I have an instrument that published a "website" with feedback information. I would like to be able to read this from a cRIO. This is very straightforward in Windows with examples such as "weather" using ActiveX and "atomic clock" using DataSocket.
Unfortunately it seems that when deployed on a RT target, DataSocket does not support HTTP.
Any suggestions?
BTW, this instrument also supports Web Services using SOAP - Again, a no brainer in Windows with the Web Services Wizard (tools>>import>>web service...) but also NFG on the RT...
QUOTE (Jolt @ Apr 9 2009, 02:54 PM)
Hello all,
Any suggestions?
All these things are one of the reason to not use ActiveX or .Net for things that can be solved otherwise. The HTTP protocol on the client side is not that terribly complicated to not implement it directly in LabVIEW.
LV_FPGA has posted his code. In the CVS repository on OpenG are some HTTP Vis too, that haven't made it into a released OpenG package yet.
Rolf Kalbermatter
QUOTE (LV_FPGA_SE @ Apr 9 2009, 10:42 PM)
Thanks! I started to play with direct TCP this last night - Unfortunately I was not successful so far, probably do to company firewall issues.
Any other examples very much appreciated and I'll work on getting code out of the CVS system soon.
BTW, I agree with rolfk - I would rather understand what I'm doing and use low-level functions, especially for simple tasks, but I haven't quite figured out all that network protocol stuff...
