Login VI
hi everybody
I have main VI which has my code i want to make login VI which is show my main VI automatically if username and password are correct.
for example: if my username and password correct run my main VI if not show message.
plz help me.
best regards
What have you tried?
Where is the problem?
  • Creating a window with two string controls?
  • Making a password control?
  • Hashing, storing, comparing passwords?
  • Program control after password verification?
QUOTE (m037_85 @ Apr 15 2009, 01:03 PM)
hi everybody
plz help me.
best regards
First think you for reply.
my problem is when password correct who can i call my main program to work( main program is another VI).
My project is:
1. i remote access to server(which has my project)
2. show Login screen
3. if correct open my project
plz help me cuz its very important in my project.
Think you again
Are you hard-coding your password(s)? Are you pulling them in from some other source?
A nudge in the right direction would be to check out comparison operators and case statements.
Or download the password class in the code repository ;)
From then on (simplest) its just a case statement with an exit function in the false frame if the password fails and your sub-vi in the true frame if it passes :)
