ku637 Posted May 16, 2009 Report Share Posted May 16, 2009 Hi all, I need to develop a hyperterminal like application in labview.I ve only lv6.1 version son cant open vis in higher versions. I a basic question 1) I need to create a sub VI using VISA ,then how to pass the resource name to the next Function from the subVI? There is a sub VI i created. it just initializes the serial port using VISA.i want to experiment this, to be used as a sub VI. I can pass the input resource name but how to get the outpt visa resource name from the sub VI...? Will the VI session will remain open..? normally i wire up duplicate resource name from visa initialize output to the next block but how to do it wen i want to put it inside a sub VI ? hope its clear now please put a jpg file of VI if possible (incase anybody is returning a VI) i cant go for higher versions becoz of license issues in my institution thanks Steve Quote Link to comment
crossrulz Posted May 19, 2009 Report Share Posted May 19, 2009 You can simply create a VISA indicator and pass the reference out that way. I create chains of VIs to read, write, change baud rate, etc. using the VISA resource reference and the error cluster. Seems to work quite well for me. Quote Link to comment
Neville D Posted May 20, 2009 Report Share Posted May 20, 2009 There are a number of Hyperterminal-like interfaces using VISA and LabVIEW, written by various people. Scott Hannahs is one of them. Search around LAVA for other examples. N. Quote Link to comment
