labview serial Port-VISA and Subvis
ku637
Hi all,
I need to develop a hyperterminal like application in labview.I ve only lv6.1 version son cant open vis in higher versions.
I a basic question
1) I need to create a sub VI using VISA ,then how to pass the resource name to the next Function from the subVI?
There is a sub VI i created. it just initializes the serial port using VISA.i want to experiment this, to be used as a sub VI.
I can pass the input resource name but how to get the outpt visa resource name from the sub VI...?
Will the VI session will remain open..?
normally i wire up duplicate resource name from visa initialize output to the next block but how to do it wen i want to put it inside a sub VI ?
hope its clear now
please put a jpg file of VI if possible (incase anybody is returning a VI) i cant go for higher versions becoz of license issues in my institution
thanks
Steve
You can simply create a VISA indicator and pass the reference out that way.
post-11268-1242652756.jpg?width=400
I create chains of VIs to read, write, change baud rate, etc. using the VISA resource reference and the error cluster. Seems to work quite well for me.
There are a number of Hyperterminal-like interfaces using VISA and LabVIEW, written by various people. Scott Hannahs is one of them. Search around LAVA for other examples.
N.
