Array Question
QUOTE (labviewnoob @ May 19 2009, 02:56 AM)
If I wish to use array to store data & take the data out to be used?
Then you would use the "Build array" to store data and "index array" or "array Subset" (Take the data out) primitives to do this.
QUOTE (labviewnoob @ May 19 2009, 06:20 PM)
Is there any better method for it? any graphical help would be welcomed. many thanks.
Make sure you learn about auto-indexing of FOR and WHILE loops.
There should be plenty of examples in the LabVIEW Examples folder.
QUOTE (labviewnoob @ May 20 2009, 02:20 AM)
In order to be helped in a more detailed way, you will probably need to give more details :) . Do you want to select a range of data? Do you want to select numbers from a specific column, row, or column and row? Is your array 1D or 2D etc? All these things will help people answer your question.
