Run EXE using System Exec
Well, the VI is not runnning, so no source code is executed at all, so "System Exec" will not be executed, at least not from the VI, it is placed in...
Regards, Jens
Yes you can, but the execution properties has to be "Run when open".
Just type:
"c:\program files\national instruments\labview 8.6\labview.exe" "c:\test1.vi"
You can read about this in the LabVIEW Help, just serach for "Launching a VI from the Command Line"
//Mikael
