werner Posted July 11, 2009 Report Posted July 11, 2009 (edited) Hi there, is it possible to set up a NumCtrl with a "wrap around". If I reach the maximum value and I press "up" again I want it to jump to the minimum number and vice versa. E.g. (pressing up again and again) 0 1 2 3 4 5 0 1 3 4 5 or (pressing down...) 5 4 3 2 1 0 5 4 3 2 1 Edited July 11, 2009 by werner Quote
jcarmody Posted July 11, 2009 Report Posted July 11, 2009 Hi there, is it possible to set up a NumCtrl with a "wrap around" [...]? You can use an Event Structure. If the value changes to 6 set it to 0, if it changes to -1, set it to 5. Quote
Francois Normandin Posted July 11, 2009 Report Posted July 11, 2009 Hi there, is it possible to set up a NumCtrl with a "wrap around". If I reach the maximum value and I press "up" again I want it to jump to the minimum number and vice versa. E.g. (pressing up again and again) 0 1 2 3 4 5 0 1 3 4 5 or (pressing down...) 5 4 3 2 1 0 5 4 3 2 1 If you have a limited and well defined number of possibilities (0-5 for example), you could use a text-ring control. You have to set the strings values from 0 to 6 and then it will go in circle when you increment or decrement. If you have a huge set of possibilities (or infinite), don't try that. jcarmody's solution is what you need. Quote
