Liang Posted July 22, 2009 Report Posted July 22, 2009 Hi, The deprecated method of "Resolving Symbolic Paths" @ LabVIEW Wiki is no more available. Can anyone upload it? It's better to teach me how to show it up. Thanks Quote
Liang Posted July 22, 2009 Author Report Posted July 22, 2009 I've found it. The private method had beed removed to "LVTarget". Quote
Phillip Brooks Posted July 22, 2009 Report Posted July 22, 2009 I've found it. The private method had beed removed to "LVTarget". The Method was available in earlier versions of LabVIEW, but changed to deprecated in LabVIEW 8.5 (I think). I've recreated a version of the file you were looking for using LabVIEW 7.0. Symbolic Path.vi (LV 7.0) Quote
Liang Posted July 22, 2009 Author Report Posted July 22, 2009 Hi Philip, Thank you very much. The Method was available in earlier versions of LabVIEW, but changed to deprecated in LabVIEW 8.5 (I think). I've recreated a version of the file you were looking for using LabVIEW 7.0. Symbolic Path.vi (LV 7.0) Quote
Aristos Queue Posted July 23, 2009 Report Posted July 23, 2009 It was deprecated, which means we strongly recommend you do not use it at all and it may be removed in the next+1 version of LabVIEW. Generally the context help of the deprecated function describes the intended replacement function or the reason why this functionality is not stable/usable/meaningful in the latest LV version. Quote
