Resolving Symbolic Paths
The deprecated method of "Resolving Symbolic Paths" @ LabVIEW Wiki is no more available.
Can anyone upload it?
Thanks
I've found it. The private method had beed removed to "LVTarget".
The Method was available in earlier versions of LabVIEW, but changed to deprecated in LabVIEW 8.5 (I think).
I've recreated a version of the file you were looking for using LabVIEW 7.0.
Symbolic Path.vi (LV 7.0)
Hi Philip,
Thank you very much.
It was deprecated, which means we strongly recommend you do not use it at all and it may be removed in the next+1 version of LabVIEW. Generally the context help of the deprecated function describes the intended replacement function or the reason why this functionality is not stable/usable/meaningful in the latest LV version.
