silmaril Posted August 6, 2009 Report Posted August 6, 2009 The Get/Set Tag methods provide very interesting possibilities of saving and retrieving additional information with controls, panels... This looks very similar to the Get/Set Variant Attribute functions. There is just one function I am missing: Is there any way to get all the tag names associated to a scripting object? Quote
Francois Normandin Posted August 6, 2009 Report Posted August 6, 2009 The Get/Set Tag methods provide very interesting possibilities of saving and retrieving additional information with controls, panels... This looks very similar to the Get/Set Variant Attribute functions. There is just one function I am missing: Is there any way to get all the tag names associated to a scripting object? Hi Silmaril, there is a method (invoke node) to retrieve all tags from a library all at once: Tag.GetNames. It's not something that exists for controls. Just a side note, you can "set" tags only is Edit Mode. But it is still a good way to store information that will not be displayed in the "description" of the terminal, especially using scripting. If you want to have a method that retrieve all Tag Names for Controls, ask for it on the LabVIEW API page. You *might* see it in the next release. Quote
silmaril Posted August 7, 2009 Author Report Posted August 7, 2009 If you want to have a method that retrieve all Tag Names for Controls, ask for it on the LabVIEW API page. You *might* see it in the next release. You are right. I just posted this request there. Now it's waiting for Christmas to see which items from the wish list will be inside all those colorfull boxes Quote
Francois Normandin Posted August 7, 2009 Report Posted August 7, 2009 You are right. I just posted this request there. Now it's waiting for Christmas to see which items from the wish list will be inside all those colorfull boxes Maybe you'll get Xmas before you know it... I found a way to retrieve all tags from a VI. I basically scan the VI file and get an index to the position of tags in the file. I then extract the tag names. Since I don't know to which objects it is related, I have to scan all objects on FP and BD to associate them properly. Once done, you get a list of refnums and variants for the Object's references and a list of tags to which it is associated. I also included an example of code to write a tag to the Block Diagram. Use the same template to write to FP or any objects. Open the project and launch "Get All Tags from VI". Browse the path to the example file "Tagged Test VI" and that's it. Saved in 8.6 but will work in 9.0 (2009) as well. Note that the versioning is important as tags are seen only through scripting and NI can change the way it is saved from one version to the other. Retrieve Tags 8.6.zip 1 1 Quote
Petru_Tarabuta Posted May 28, 2025 Report Posted May 28, 2025 Hi Francois, Thanks for creating the code inside Retrieve Tags 8.6.zip. The code inside the zip file works perfectly for me. Specifically, when running Get All Tags from VI.vi I am getting all tags stored inside the Tagged Test VI.vi. Ideally I would like to use Get All Tags from VI.vi to inspect the tags inside VIs saved using the latest versions of LabVIEW (2024 Q3 and 2025Q1). As far as I can tell Get All Tags from VI.vi works only on VIs saved in LabVIEW 8.6 or LabVIEW 2009. This is because each version of LabVIEW uses a hardcoded six-byte string. VIs saved in 8.6 use "0860 8001 0000" while VIs saved in 2009 use "0900 8000 0000". Do you know what the corresponding six-byte sequences are for the latest versions of LabVIEW? Is there a more generic way of finding the tag names, one that does not require a six-byte sequence for each LabVIEW version? Many thanks, Petru Quote
Darren Posted May 28, 2025 Report Posted May 28, 2025 You can use this private method to get all the tag names from a VI. Quote
acaracciolo Posted September 9, 2025 Report Posted September 9, 2025 (edited) @Petru_Tarabuta If you are still looking for all the object tags rather than VI tags consider the examples below as it is LV version agnostic (or at least agnostic since the VI file format standard this tool supports). One thing to note is the method mentioned above assumes printable characters are in the tag name. Using the low level VI manipulation vi explorer from here https://github.com/flarn2006/VILab is a good way to see this. I think you are better off keying off "Tag Name" since tag names technically don't have to be printable ASCII. See example snip where DEADBEEF in hex would not be printable. Edited September 9, 2025 by acaracciolo Quote
