Clio75 Posted August 20, 2009 Report Posted August 20, 2009 Is there a way of finding all GPIB/VISA/Serial instruments connected to the system programmatic ? (get the same list as VISA showing) When I have found all instruments I need I can start the test. Offen (or always) when I move a system from development to the real test, instruments have not the same setting as I have in the R&D. So If I find a way to find the instruments programmatic this will solve many problems. Thanx Quote
crossrulz Posted August 20, 2009 Report Posted August 20, 2009 On 8/20/2009 at 9:13 AM, Clio75 said: Is there a way of finding all GPIB/VISA/Serial instruments connected to the system programmatic ? (get the same list as VISA showing) When I have found all instruments I need I can start the test. Offen (or always) when I move a system from development to the real test, instruments have not the same setting as I have in the R&D. So If I find a way to find the instruments programmatic this will solve many problems. Thanx Like the VISA Find Resource Quote
Clio75 Posted August 20, 2009 Author Report Posted August 20, 2009 :worshippy:Thanx Have you ever used it ? If so can you give me an example. (if not I must test this ASAP) Thanx Quote
crossrulz Posted August 20, 2009 Report Posted August 20, 2009 On 8/20/2009 at 12:04 PM, Clio75 said: :worshippy:Thanx Have you ever used it ? If so can you give me an example. (if not I must test this ASAP) Thanx I made this one to find the serial ports available in a system. Get List of Serial Ports.viFetching info... Quote
Clio75 Posted August 20, 2009 Author Report Posted August 20, 2009 (edited) Thanx Thanx Edited August 20, 2009 by Clio75 Quote
