X Control With Dynamic Screen
jgcode
Howdy!
Is it possible to have an X control that can spawn a dynamic User Interface VI - such that the UI is non-blocking in the X control thread? I have done X Control with static UI - easy. I just want to know if it's there is any problems that may arise or it anyone else does that before I go down that path.
Right know I have my control in a main VI and I have a separate UI that runs in parallel to the main VI and that "acts" only on the control.
The parallel UI is run by by main VI and comms/data go through the main VI to the control.
I would like to encapsulate the control and parallel UI together.
However, the UI and control must run at the same time - the parallel UI cannot block the control.
Would this work ok?
Cheers
JG
Edited by jgcode
Should be fine. (havn't tried what your doing but have done similar things).
There is a flashing LED x-control around somewhere here that spawns a vi dynamically as a timer which is similar to what you are tring to achieve.
Sweet, I remember seeing that one posted, I will check it out.
I think that is the way I am going to go.
