VI to C/C++ code?
Lodestar
With the LabVIEW embedded module you can create ANSI C code from your LabVIEW code, however a lot of functionality is not avalaible.
Why do you need your code as C/C++?
You could build a DLL from your VI and call that from C.
Ton
Ton, Thank you very much.
I can change LV program to C/C++ code using microprosser SDK now.
The variation reason is that I need to write a special instruction with C/C++ code.
I prefer dlls myself, but for a single instruction it might be worth looking at CINs rather than converting a whole piece of LV code to C. Especially if you already have the code.
Theres a very good tutorial HERE
