Exception occured in ADODB.Recordset
Hi ,
Does anyone of you have the experience when doing some operation with the database ?
I have an error occurs when I tried to insert oe delete the records in MS access. The error is show in this following ....
Exception occured in ADODB.Recordset: Operation is not allowed when the object is closed.
Help Path is C:\WINDOWS\HELP\ADO270.CHM and context 1240653 in Verified_ver01.vi "
However, the new data is inserted or deleted to the database, but the above error is also consistantly show.
This error is NOT occur if I use the query command such as " Select * from XXxxxx " , but it does occur for the Insert or Delete command.
If you have an experience or idea to fix this problem, please advise me.
Thank you.
I think your "Writing VI" to the database also assumes that some data should be returned, i.e. that you ran a SELECT Statement.
Make sure you have the option set to not assume a response.
Cheers,
Mikael
Cheers,
Mikael
I also found another error in this following message ...
" Exception occured in ADODB.Recordset: Operation is not allowed when the object is closed.Help Path is C:\WINDOWS\HELP\ADO270.CHM and context 1240653 in Verified_ver01.vi"
This is occured when i used Update command.
T_T
